Vinyl Application
I have done many vinal graphic wraps. You have to do sections at a time and apply with soapy water and a squegee.
What do you need to know about it? I installed it on my F350.
WET!
If you put it on dry, once it's down, it's down, air bubbles and all.... use soapy water and you can move it around a bit and get the air out.
the soap and water does not hurt the adhesive unless the soap and water is sprayed over and over for a long period of time without being able to apply the vinyl (and it would take a really long time for that to start happening). as stated it is just to allow you to move the vinyl around to the position where you want it. then when you squeegee it, you are getting the soap and water out. once the soap and water is out the adhesive starts to do its thing and tacks down, allowing you to move further and further down the side of the car or whatever. I have wrapped tons of racecars and haulers and as long as you do section by section you should be fine.
