rockmafia Well-Known Member Joined Apr 2, 2006 Location sedalia nc Feb 3, 2008 #1 Where is it on a 97 5.7?
sha_ba_do_bang Joined the Band Banned Joined Aug 11, 2005 Location Wilmington Feb 3, 2008 #2 In the distributor
Blkvoodoo professionally useless Moderator Joined Mar 16, 2005 Location Archer Lodge Feb 3, 2008 #3 Yes, in the dizzy, under the rotor, if you are getting cam sensor code, check your dizzy for shaft side play as well. Those engines are good for wearing out the plastic housings.
sha_ba_do_bang Joined the Band Banned Joined Aug 11, 2005 Location Wilmington Feb 3, 2008 #4 And those engines also eat the gear off the cam that drives the dizzy and a bad crank sensor can set off the cam sensor code
rockmafia Well-Known Member Joined Apr 2, 2006 Location sedalia nc Feb 11, 2008 #6 I guess it has to be plugged in to work
Blkvoodoo professionally useless Moderator Joined Mar 16, 2005 Location Archer Lodge Feb 11, 2008 #7 rockmafia said: I guess it has to be plugged in to work Click to expand... Umm, yeah, that does help
