rockcity
everyday is a chance to get better
- Apr 10, 2005
- Greenville, NC
OK, I'm selling the house and I need to repair some floor joists due to VERY slight water damage. The buyer's inspector made note of the damage and his suggestion is not what I want to do. Its way too involved and expensive and IMO, not necessary...
There is moisture in the crawl space due to the main A/C duct condensating. This will be insulated more to take care of the moisture. But, I have to repair a few floor joists and some on the main girder. The damage is about 1/4" thick on the bottom 1/4 of the joists and is spotty on the floor joists in areas about 2' on either side of the girder. This damage is not significant enough to compromise the integrity of the floor joist, yet. But, it must be repaired. I can take care of this fairly easy with a sister joist.
My main concern is the main girder. Only the bottom 1/4" of the triple 2x10s is damaged however, the home inspector (not county inspector) said he was expecting to see the girder removed and a new section installed. This is going to be a major PITA and will be more $$$ than I want to spend.
I am a contractor and can do the work, but I don't know the correct way to repair this without replacing the main girder section, if any. Does anyone have any experience in this type of work? I feel awkward asking for help, but I specialize in heavy industrial construction and have no real experience in residential and even less in joist/girder repairs.
I want to repair this the fastest and cheapest way that will keep the house within code and pass inspection by the buyer's home inspector. I'm not as concerned about the inspector as I am about following code because regardless what the opinion of the inspector is, as long as I follow code I will be fine. Repair code is to meet regulations as current code regardless of the age of the house.
Already, the inspector said he expected to see treated lumber in there for the joists and girder but treated lumber is not required per NC code. So, my thoughts were that the inspector may be looking/expecting/recommending overkill and I don't want to spend $1000 when $200 will work.
Ideas? Options? Concerns?
I have researched this quite a bit in the last couple of days and have some ideas, but I'd like to get the opinions/suggestions of anyone that may have experience in this type of repair.
I have pics for anyone that is interested in offering any suggestions.
Help! I close on July 30th on the new house and need to get this house taken care of ASAP.
Thanks
Thanks
But I'm still a tad young and I'm sure my philosophy will change with age.
It had more than 2" total damage at one spot.
