Water in the Gas Tank
randyszj94
greensboro
no no wasn't me, but some1 poured water in their gas tank by mistake (dont ask how) and ask me to fix it... im thinking
Drop gas tank and drain/clean, change filter and take out spark plugs and run motor, try to piss out anything in it... anybody else got some ideas how to remove the water?
How much water? If it's only a very small amount, you can put a pint of rubbing alcohol in it to dissipate the water. If large amount, you'll have to drain it.
what kind of vehicle? can you disconnect the line and let it pump itself out?
has it been run since the water was put into it or is it just sitting in the tank??
is a minivan so im guess fuel injection, i think she said they put over 1 gallon of water in it and it has been running ....
