RatLabGuy
- May 18, 2005
- Churchville, MD
Looking for some advice/ideas on sealing a large 3d printed part so its water-tight.
Need a spray, or maybe brush-on material that will dry smooth, but can be applied to something that is an irregular bowl-shape (each side of the inverse mold to cast a human head).
Typical printed ABS is slightly porous at each layer, so fluids tend to seep inside. Need to seal that while maintaining a smooth finish (or at worst leaving the print layers, but ideally they go away too).
Would the infamous Flex Seal work? Other kind of silicone spray? An epoxy finish that runs juuuust enough to not leave brush strokes but not pool toward the bottom?
We tried a handful of thin layers of Plasti dip spray and still got a small amount of leeching. Maybe not enough b/c you can still see the print lines...?
. we tried it with a small part but it didn't do much. I suspect bc we didn't use enough acetone for the volume in te hoven - to do this with such a large piece (2 really ) it would take a massive amount. And again - most people don't have a vacuum oven laying around.
Anyway, I bought it to try and seal PLA prints for grins and giggles. Might be worth a shot. I haven't tried it yet. I'm assuming it will go on thin and smooth, like an average conformal coating. Oddly, the website that recommended it was using it to seal printed sex toys, and seemed to take bacterial growth very seriously, so I think I can trust their research. Would it be food safe? Probably not. I think it would eventually wear off. But for your application, it may be perfect, and easier than a brush-on 2-part epoxy product. It comes in a spray can. I'll try to find a link.
Sorry about that
