rattlecanpaint
- Apr 18, 2005
- Winston Salem
First a little history. It's been running rich since I got it but it ran OK. Drove it to work the last 3 days, drove it around last night and on the way home got fuel. This was about 11:30 last night. Today on the way to work the 4runner started running like absolute crap. Fortunately it's only a mile and a half to work and there's only one stop light. Had to keep one foot on the gas to keep it (sort of) running. It's running really rich, smells horrible and is blowing black smoke like a diesel. Carb only has about 1000 miles on it. Had a buddy pinch off the fuel line to the carb with his fingers and it purrs like a kitten. Let off and it continues to run OK till you give it some gas then it's back to barely running, missing, bucking etc. We figured the pressure regulator in the fuel pump was bad so I installed a new one. Still does it.
When I removed the air cleaner and looked down the throat of the carb there is (what seems to me like) way too much fuel coming out of the carb at just off idle. I'm guessing you should just see a mist of fuel, not liquid pouring onto the throttle plate. Am I wrong here? I pulled the top off the carb and checked the needle thinking there might have been something stuck in it but it's clean. Pulled the air jets off to see if they were plugged but they look clean too. Any ideas, or is it just possible bad gas? (In dealing with BMW's and bad gas they won't idle or in some cases even start but it's a constant thing not like this one where it will idle after pinching off the fuel line. Anyone heard of anything like this or have any ideas?
