frankenyoter
No Rain, No Rainbow
- Mar 17, 2009
- DARK CITY
I just got the rear third welded together for my FJ60. Basically my issue is that the spider gears are slightly off from each other. We tack welded everything together with the pinion pin installed. Then removed the pinon pin and finished. Now it takes a hammer to get the pin all the way in. This could be an issue to remove the c clip and get the axles out later.
My question is this: would there be any problem with sanding down one side only where it goes into the other spider less than a 1/16" to make it drop in?
Thanks for help!
Thanks for help!
