72Rockcruiser
LETS GO BRANDON!
- Mar 22, 2005
- Charlotte, NC
Weld it!
Weld it!
So my question is, why do you not have to worry about tire wear with a locker. The only benifit is that you are not locked coasting. If you are on the gas at all, they are locked like a spool. So pulling in a parking spot, driving through a parking lot, and making tight turns will cause your tires to wear just like a welded rear if you are under power.
Just how hard to you pull into parking spots??!!
I believe lockers will still unlock at low power input if the bind is enuff to overcome the springs.
Why would there be a difference between a spool and welded?Highway speeds on a welded rearend are going to be different than highway speeds for me.
so pick one little thing out that is shady. I guess I should have said pulling out of a parking spot.
how did i know u would say weld it?
I spooled my CJ5. It squeals like crazy in parking lots. Everybody stares at you.
Sorry, I know this is an old thread, but this needs to be addressed. A lunchbox locker will always allow a tire to be overdriven. Example: If you're powering through a turn, the outside tire is turning at a higher speed than the carrier. When that happens, the cam driver doesn't have pressure on it from the cross shaft and it can ratchet. So, a tire can actually spin faster than the carrier, but never slower. This process isn't seamless unless you're very steady on the skinny pedal. If you can hold a perfect amount of throttle around a turn and not "check up" on the gas, you can make very smooth turns with a lunchbox locker.justjeepin86 said:So my question is, why do you not have to worry about tire wear with a locker. The only benifit is that you are not locked coasting. If you are on the gas at all, they are locked like a spool. So pulling in a parking spot, driving through a parking lot, and making tight turns will cause your tires to wear just like a welded rear if you are under power.
If you like ur tires, dont weld it up. I welded my d35 with 33's on it. Real bad tire wear in the back. And it chirped around every corner.
