Welder popping?
CThurmond
china grove nc
I have A clarke 180en i am using with 75/25 gas and hobart .30 wire and tips
Im welding 1/4 inch on high setting 8.2 wire speed. I have been working on my jeep for 4 months with these settings.
Now randomly the welder keeps popping and welding my wire to the end of the tip( inside the tip) ? Just a real loud pop and then wire feed stops.
Ruined 3 tips in less then 20 mins...
New tips ...spool is a few weeks old.
How can i stop this?
Sent from my LG-H631 using Tapatalk
Tips are same as wire .30
I used anti spatter after the first tip. Didnt seem to change for good or bad.
Going to try to get a few scrap welds tomorrow to see of its a wire feed problem.
Try clipping the ball off the end if your wire before you start a weld. Also check spool tension and drivewheel tension to be sure it is feeding properly.
make sure your torch is laid out straight. sometimes they don't like pushing around tight turns
I have this kind of issue with my Miller 252 sometimes when using a moderate to slow wire feed rate and trying to "kink" up the torch lead to get into a tight spot. The solution is always to straighten out the torch lead.
It turned out to be a kink in my wire. I hand pulled about 3 feet through and there was a real bad kink.
Not sure how it got bent up, but keeping my lead laid out seems to be kelping.
I use the welder about 2 times a week. Lately ive been running it 5 days a week though. I bought the welder a lil over a year ago and ive only ran through 25 lbs of wire and one #3 bottle of gas.
Glad you found the issue!
I'll also second watching the routing of your torch lead. Just about every time I have a wire feed issue I'll look down and see that I've got a really tight curve in the lead! It drives me crazy sometimes when I am trying to get into oddly positioned welds!
