ok I have a problem, I'm almost out of gas!! for the first few days it seemed like I was using it fast so I sprayed soapy water on it and sure enough there was a small leek at the regulator but I took it off and put teflon tape on it and then it wasn't leaking any more. so I didn't use it much for a while and as of two days ago it was about 3000 psi. I started welding a good bit in the last few days and today it was just dropping like crazy, I welded like two braces on the bottom of the jeep then one square foot of sheet metal and its at the lowest tick mark now, I always turn it off after I stop welding and I don't feel like I'm welding a ton, it just seems like it went too fast, Today I have sprayed soapy water EVERYWHERE and no bubble or apparent leeks, What am I doing wrong? Is it possible the regulator is wrong or do you think there is a leak I can't find?
