Hey all, I need some welding help in Charlotte.
I have a 97 TJ that was getting a new RC 6'' X-Series lift (I know! I'm sorry, it was the only one I could afford). Welp, Houston has a problem!
1. Weld lower control arm brackets to the axle. After taking everything apart, I noticed one was beyond saving and needed to be replaced. So, I'm going to replace them both.
2. I botched the installation of my front Track Bar relocation bracket. You're supposed to drill wholes STRAIGHT through the frame, install crush proof sleeves, and bolt the damn thing down. Welp, I didn't straight and had to bore the wholes out. Now, I'm EFFED! Here's the plan for the fix;
a. Weld the crush proof sleeves inside the frame
b. Weld the bracket to the frame in addition.
I have a Lincoln "Buzzbox" AC225 Stick Welder and I'm horrible at welding. I have rods, but I'm not 100% sure of the amperage or proper rod, even after researching online.
I'll supply the beer and some cash for your troubles! Honestly, I don't have a ton of money to spend on getting this stuff welded- hence the request for help. Everything I've been quoted has been astronomical and I'd really like to get her back on the road.
Any and all help is greatly appreciated!
