Blaze
The Jeeper Reaper
- Aug 9, 2005
- Wake Forest, NC
So I am afraid my well pump might be dying out, but I am not a well pump expert so I am not sure.
Well pump is from 1994, sits 250ft down in my well, not sure how deep my well is.
The pressure switch under the house must have been replaced at some point because I found the cover off of a different one while I was down there.
A few weeks ago I was working on the house and I pressure washed the front of my house. No problem at all. Later in the day I was filling up a small kiddie pool in the back yard and my wife was washing dishes and the water stopped. I turned it all off and 5 minutes later it was all back to normal.
No problems until yesterday. We were having a birthday party for my son so I was filling up the kiddie pool again and we were washing dishes and the water stopped again. I went to the breaker panel and cycled the power and the water came back on. About an hour later it happened again. Turned water off, waited and it came back on fine. No problems till later in the day when my son wanted to try out his new slip and slide. We had it hooked up and the water was spraying out fine and then the pressure dropped down. I climbed under the house to the tank and switch and checked the gauge. The pressure was sitting at like 30lbs and then it would jump up to 60lbs for a little while and then drop back down to 30-40lbs and sit there for a while before jumping back up. Spent more time at 30lbs than 60lbs. Today no problems at all, but the pressure seems to be lower than normal, probably more at 30lbs than 60lbs.
Do you think it might be the pressure switch? In one of my old houses the tube between the feed and pressure switch got plugged up and it caused problems, but it was just an on-off issues and not a pressure issue. I mean, maybe it is partially clogged and not seeing the right pressure and I am reading actual pressure downstream of the switch on the gauge.
Now that I am typing this I kind of see how it could be the switch so since that is cheap maybe I'll replace it and clean the inlet tube tomorrow.
Any other ideas though?
