Wetsounds Stealth Series Sound Bars at Motobilt.com
motobilt
Dothan, AL
awww.motobilt.com_media_catalog_product_cache_1_image_451cfaafba0d67301f5449f44e5cb23b066f4010.png
STEALTH SERIES Sound Bars represent the world’s first universal high performance plug and play sound system for Side by Side’s, ATV’s and golf carts. The patent pending design is built with a full extruded aluminum housing which have the same styling as our Rogue 4 led light bars. Both STEALTH models feature a Bluetooth enabled Audio Receiver with a High Performance speaker array and titanium dome tweeters for a rich and dynamic full range performance. They are powered by a full range class D amplifier that also features auxiliary inputs, 2 volt line driver output to link to another sound bar or to add external amplifier and speakers, waterproof connector, universal L mount brackets for end cap mounting or sliding top mount channel system, auto turn off feature to save battery life, back lit led illuminated control panel and a fully integrated wiring harness included. The Stealth Sound Bars are true High Performance plug and play stealth audio system!
Extruded Aluminum Housing
Stainless Steel Hardware
Eight Wet Sounds 3 inch full range marine drivers
Two Wet Sounds 1 inch titanium tweeters
Built in Bluetooth
Improved Bass Response
Fits RZR
New Connectors
Auxiliary Inputs
Auxiliary output with 2 volt line driver
Built in 300 watt full range class D amplifier
Aluminum L bracket mounting system
Sliding mount channel for add on accessory top or bottom mounting system
Backlit control panel for power, volume, source selection, track control, pause/play on BT and Mute on aux input
Automatic Shut off system that turns itself off after 10 minutes of no source to not drain battery system
Water Proof screw on wiring harness
Fully jacketed waterproof wiring harness included
