what do i have to do to clear 33's on my 93 sub
You should be able to clear 33s with a little crank of the factory torsion bars or you can trim a little off the bumper and take a hammer to the back of the fenders.
You can fit 33s but you will have to crank the torsion bars, and that leads to one crappy ride. Or you can get a couple new keys and lift it 1-2 inches and you should be OK
I thought you could crank torsion bars with out getting new keys. I thought new keys was a lift without cranking the torsion bars. You learn something new everyday.
33 tires
had 32's on my stock 94 k1500 with 8 in rims. switched to 10 in rims and had to cut the front plastic under the bumper. whent to 33s and had to trim the corner of the bumper. would scrub in the inner fender. cranked up the t bars and no more problems. the tire was all in the fender though. a 3 inch body lift made it look a lot better. could fit 35s on stock wheel. wouldnt fit with the 10 inch wide rims.
