lets make this easy. 1988 4x4 toyota truck, w56 trans. trashed. truck has a 22re engine. will a 1993 4x4 w/ 22re trans / tranfer bolt in with no modifications. any help? thanks
LARRY YOU MAKE IT SOUND TOO EASY..MORE INFO, IM KEEPING MY ENGINE AND BOLTING THE TRANS / TRANSFER COMBO FROM THE 93 IN. THE INTERCHANGE LISTING FROM THE SALVAGE YARD SAYS THE ONLY COMBO BOLT IN I CAN USE IS 84 TO 88 W SERIES. WHY WON'T THE 93 TRANS / TRANSFER BOLT TO MY 22RE?
just swapped a 22re/w56/dual cases in a 84 x cab. everything bolted and plugged up, had to swap a few sending units tho. otherwise, so simple a caveman can do it
