I have a leaf sprung CJ using stock YJ springs SOA. I don’t think that information matters for my question, but there it is just in case. My question is what is the general opinion on how best to set up for flex? My current setup has about 80% of the axle travel in the down direction. What I mean is my shocks can extend about 8 inches and have 2 inches compression available at rest.
In my way of thinking, I should keep the tires on the ground if at all possible, so the bias towards extension allows following terrain contour easier. If the tire is hanging in the air, it can’t provide any traction. A problem with this is the need for limiting straps, suck down winches, etc. so you don’t get too much extension when climbing or descending. It also allows significant body lean on side hills, which could make a roll over more likely.
On the other hand, limiting the extension makes it more likely one tire will be off the ground in rough terrain. I guess this would be less of an issue with front and rear lockers, but may be critical for open diffs. I think this would minimize the need for limiting straps and suck down winches, and would provide more stability on side hills. Body lean should be limited by the additional force required to lift the up-side tires.
So, is there a leading opinion, or is it pretty much up to whatever you want to do?
