marty79
- Nov 24, 2013
- Newton, NC
hey guys so my welder all of a sudden started just spewing wire at full speed then made weird sounds (like when you accidently touch the lead to your piece and shorts it out) then it threw the breaker.
It will turn on but wire is stuck wide open.
I disconnected wire circuit and that stops but will only run for maybe 20sec cause you can start hearing the "transformer maybe??" making noise like it's bogging down than throws the breaker..so this sucks major butt cause I'm at a standstill now
Any help ideas anyone, thank you
It's a Century 2225 Solar Welder, 208/230 volts (wired for 230 currently)
The nose it makes sounds to be from rear of machine...
I realized apparently when I was using my plasma cutter on the rear axle and maybe the welder was still on(don't remember) with ground clamp hooked up...would that have done something?
