What psi?
Matt B
Member
I have BFG Rugged Trail_LT265/70/17_Load E tires on my Dodge 1500 Mega Cab (2500 chasis). The max psi for the tires is 80.......For everyday driving what is the best/safest psi to run? I want these tires to last as long as possible.
On a side note - what is the difference in running a "P" tire vs a "LT" on my tuck?
Probably around 55 front and 45-50 rear.
P tires are passenger car tires and have much more flexible sidewalls and quieter tread designs. An LT tire particularly in a load range E will have a much stiffer sidewall, but also can carry a lot more weight. I imagine a typical P tire is rated at 2000lbs per tire, whereas an LT load range E would be rated at around 3500lbs per tire.
I only run about 35-40psi in the rears on my 2500 when its empty.
I don't know that there's a "right" number... but on a pickup, the pressure numbers on the door usually account for there being some load in the truck.
I run the numbers on the door sticker except a little less in the rear since I'm not running around with 1,500 lbs in the bed.
