jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
I'm trying to sell the wife's 4runner. I took it to Toyota of Gastonia week before last for oil change and tire balancing. The tires were fine, but you could feel an ever so slightly shake on occasion at higher speeds. The tires are stock size 265/60r18 Dick Cepek Trail Country that I bought new. They have 20k miles on them and are still at about 65% tread. Ive had them balanced before elsewhere when the 4runner still had michelins, and it was never perfect, until the dealer did it and they were fantastic. So ive been having the wife get them balanced about every 10k miles, which only once a year.
So the dealer balanced the tires, and the road home from the dealer is country backroads with nothing over about 50mph and they seemed fine. The next time I drove it was to meet some potential buyers, and as soon as I got on the interstate, I had a constant steering wheel shake from about 60-70mph. I informed the buyer of this, and told them I'd have it fixed Monday morning. Took it back to Toyota of Gastonia, and they rebalanced them. I'm pretty sure it's now worse than the first time they balanced them, and at a wider range of speeds. I know in the past, they have used stick on weights on the inside of the wheel. It was the same tech on the balance and rebalance, and both times they used hammer on weights on the outside. I've read that 4runners are very sensitive to balance issues, and that you're supposed to use a particular type of adapter the holds the wheel by the lugs, and use dual plane balancing. It appears they did dual plane balancingb because on one wheel the weights are about 180 degrees apart, and two wheels have the weights about 45 degrees apart, and the 4th has them in the same location circumferentially. I'm tempted to take all the weights off, drive it, and see if it's better. Some of them are the big ol 3" long weights that I've seen used on wheels with mud tires.
So if you've read this far, thanks! Haha. My dilemma is: Do I take it back to Toyota and have them "fix" it a 3rd time? Take it somewhere else and ask Toyota to refund me for the balancing? Or just rip the weights off and send it? The potential buyer wants to buy it, but they understandably want me to sort out the balance issue first. I figure if I take it back to Toyota, they will tell me it's those "aggressive" tires causing the issue and they are not at fault. But in the past they have done a better job than other places, so I'm also reluctant to take it elsewhere. I wish I hadn't done anything, because it was practically unnoticeable before this saga started.
