what transfercase......
ive got another rolling chasis id like to swap the body of my jeep and its drive train onto, but the front axle is dsd not psd and if there is a case that will bolt right up it would made things a lot easier and cheaper
If I remember correctly there isn't one. The Ford D20 is DSD but it has an incompatible bolt pattern so it won't bolt to the T15. You may want to consider swapping to a Ford tranny that will work with an amc bellhousing.
Billybob is correct. The ford & international are both PSD. Additionally, the ford version does not share the Jeep "Texas" bolt pattern. Really, the bolt pattern is what limits you. You will only find Spicer T-cases w/ that bolt pattern. I think an adapter plate may be your best option.
thanks guys, i didnt find one that would work from my searches. but wanted some other opinions. i made some measurements tonight and it looks like i will have room for a longer trans so i may try and find an ax15 and hang a 241 or something of the back
