Whats it worth? This is my fathers truck and he is tired of messing with it.
1998 Chevy Suburban 1500 4wd around 203k miles have owned since around 2000 purchased with around 50k. Truck is clean with cold A/C.
ISSUES:
-Check engine light comes on when under a load and shakes when speeds hit around 65 mph. I believe its a cylinder 4 misfire. Will go off on its own after driving it for a while. Never had issues with it pass inspection as long as you don't do 65 on the way to the inspection shop.
-ABS light is now on all the time now.
-Sometimes the security light comes on
Have replaced all injectors, spark plugs, dis cap, rotor and wires, oxygen sensor fuel pump, fuel pressure control module, water pump and belt, starter.
Truck doesn't get driven much because of the issues. Really only used to run to Home Depot and around town. Its been a secondary vehicle for for the last 5ish years
ISSUES:
