What's it worth? NV4500 K2500
shelby27604
Efland NC
I am thinking about selling my 1996 K2500, NV4500, it is 4wd, 5.7l, FF 14B with 4.10 gears and factory locker. Regular cab, manual windows, 205k on the clock....new fuel pump, new battery, 10k miles on store brand 31" AT's, basic maint. up to date (plugs, wires, coolant, oil, transfer ATF, and Axles filled with fresh gear lube in the last 10k)
Biggest issue is probably that the blower fan doesn't run on the high setting, dash wiggles a bit, and paint is a re-spray.
I have a crew cab K3500 454/NV4500 and a 2wd MJ.....this one just isn't really needed....wondering if she can be used to free up some cash for other projects.
Can you post some pics? That might help, but I'd say somewhere between 3500 and 5000 without seeing it.
I'd say worth about 1000$ im very interested at the price to might I add!!! :D
I guess I should expect a response like that from this forum! Probably going to set my sights a bit higher than that.....normally I check the going rate for comparable vehicles on craigslist......but I only find a couple of OBS HD trucks with stick shifts, one is pretty rusty, and the other is a 6.5l TD. I will clean her up this weekend and post it up on the forum before I go to craigslist.
The best part of it is the transmission!
Yeah I had to try!! Going rate or a clean one in my neck of woods is roughly 3500-5500! Glws Def post pics on here first tho it'll more than likely go to a good home.
