What's your TPS WOT voltage? Jeep 2.5...
With a manufacture date of 5-06 I would assume early.
It's the same as the 95 YJ TPS that I had a donor motor from before this remaned motor. I got one for a 97 Wrangler at the parts store and it had a different style plug connector. I assume that was the the later OBDII style.
Where is the LDP plug for the EVAP system?
I got all the EVAP stuff off of ebay that I threw away earlier and now can't find the plug...hmmm...
So i am haviing the exact same problem Indy is having, first i got two codes. po121 and 122. Replaced the tps and still got low voltage at the tps. but, when checking the wires i was gettin 4.8v right up to it, swapped the tps out checked the codes again and all the codes are gone but right away now i have po123 which is high voltage at the tps. still back firing through the exhaust and intake, terrible gas mileage and sluggish acceleration. I also have a 97 TJ. Any suggestions?
Also to add to that it doesnt like to turn over when its starting, always started on the first crank now sometimes it takes 2-4 tries before she will turn over. sounds like it isnt even getting fuel.
