Wheel Bearing Replacement Shop in Raleigh?
Stankoma
Yearly Wheeler
Wake Forest, NC
OK, I'm fairly certain that's it is the wheel bearing that's gone bad on my Tacoma. So where to get this replaced at in Raleigh? I live in N. Raleigh, work downtown Raleigh. Is there a place that will press out the bearing and replace it at the same shop? Last time I took it to Toyota to get a wheel bearing replaced they had to sub out the work to a machine shop to get it pressed off so that was an extra $100. If that's normal, then so be-it. But where do you recommend? The shop must have the part in stock too since I need this done ASAP.
It's a PITA to get those bearings in and out. Even the dealer in town sends the spindles out to get the job done. A few of the shops here in town told me to just find a set of junkyard spindles and swap out. That's what I did after replacing one wheel bearing myself
