wheel spacer ?
adam greene
morganton
i bought some wheel spacers for my 93 dodge dually from rides yesterday, well i went to put them on and my studs are 5/8 on my truck and i cant find a lug nut 5/8 that will fit down inside the spacer to tighten it up against the hub, anyone ever run into this before.
There are lug nuts made with a smaller wrench size to fit mag wheels or spacers. I bought some for 9/16 studs , I guess they are availabe for 5/8 as well.
may just end up having to machine out the holes to put the nuts on if you can't find the certain size nuts you need. Let me know if we can help.
check the excaliber website for lugnuts. they have some 5/8 with 1" wrench size. look under circle track lugnuts section.
usually they give you lug nuts with the spacers that take a reduced size socket, like a 19mm instead of a 22mm or whatever..
