zjcrazy said:thanks for the help... I finally got an 8.8 under my zj, but it is off center pretty badly... the left side is pretty even and the right side is about an inch to far out.
I was planning on just taking out one spacer and be done with it, but I guess the thing I need to do is get an adjustable trac bar in the rear and crank to the drivers side. I guess I will also need to get wheelspacers that are a hair narrower.
I suppose it really isn't a huge deal, but it bugs the hell out of me.
cherokee91red said:Leaf springs baby :Rockon: Now track bars to worry about, and much easier to set up for a swap.
Puma297 said:coils > leafs
(even thought leafs flex better, are easier to adjust ride height, are cheaper, and are generally better than coils all the way around. )
[/leaf envy]
Puma297 said:even thought leafs flex better, are easier to adjust ride height, are cheaper, and are generally better than coils all the way around. )
Rich said:Yes, my leaf setup has great flex, but not as much as if I had put the time into a link/coil suspension. Easier to adjust height? not really. cheaper? no way. junkyard coils are just as cheap, and a pair of Alcan leaves are $400+ shipping. $200 or less will buy me a pair of coils, shipped.
Puma297 said:by adjustability in height I mean add a leaf or take one out.
zjcrazy said:I can't wait to just get longarms and not have to worry about the trac - bar.
Anyway
Thanks again
Lee said:you will still have to worry with a trackbar, long arms do nothing for the trackbar
Rich said:Which alters the spring rate, as well as the height...
Slipping a 1" spacer between the coil and the bucket is far easier (to me) than loosening the u-bolts, dropping the axle away, clamping the leaf pack, unbolting the center pin, adding in the new leaf, and re-assembling the whole thing... assuming the center pin isn't boogered up, and you haven't worn out the u-bolt nuts.
Just my $.02
Puma297 said:unless you ditch the four link setup
Lee said:you mean 5 link, If you go to 4 link you will have no trackbar
