Where should I put my onboard AIR
Clifford
sanford
I have a Viair onboard air system. I am wondering where should I put the compressor, and where should I put the air tank. I am pulling my back seat out and putting a fuel cell and some other things back there. I am thinking about putting my air tank under the jeep just above the frame. If you have any suggestions can you please help me. Thanks.
Between the frame rails above the rear axle if you have the room.
I would put the compressor itself on the fenderwell in the front.
yes i will have room because i am pulling my gas tank off and putting a fuel cell in the back. Thanks for the suggestion
I use a 20 lb fire extinguisher bottle for a tank and it is mounted on the drivers side fender well under the hood fits perfect!
