paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
Real question, what would Toad do?
What about a roller cam 5.7 tbi?
He already said to stick with the 4.3 but if I was doing a swap to go LSReal question, what would Toad do?
a 360 sounds good.... or do an AMC motor because it is a Jeep..![]()
hmmmm,I get by with 60 horse flat head so your 4.3 being under powered falls short with me. Toyotas can pull the space shuttle stock soooo what ya trying to do?. The 4.3 is underpowered for my use but I was considering building a screamer,.
5000 lb rig. So many times it doesn't have enough ass to jump out of a hole or over the rocks that I need to get over. MOST of the time it totally rocks but who wants to leave anything alone?hmmmm,I get by with 60 horse flat head so your 4.3 being under powered falls short with me. Toyotas can pull the space shuttle stock soooo what ya trying to do?
I know, that's why this ain't gonna happen... And no AMC in this one, it is originally a Kaiser with a 225 Buick motor. I even considered getting a Buick 350 and TBIing it but there is always cooling issues with them in that swap. Plus its a very old motor.If you feel like messing with a wiring harness, moving motor mounts, changing bell housings (?), potentially changing some of your exhaust, potentially changing your cooling needs, and potentially changing some of your fuel line routing/adding a return, then do the LS.
If not, keep the tried and true 4.3
might be time to go on a diet. You weigh only 1200 pounds less than my 92 f350 CCUB.5000 lb rig.
I've already gone through all of my gear and reduced it. Took off spare and carrier. I will be cutting down my front bumper and reworking my rocker guards because they are built with thick steel (early build mistakes) but I'm not going to be able to reduce but maybe 200 lbs...but every little bit helps.might be time to go on a diet. You weigh only 1200 pounds less than my 92 f350 CCUB.
No carbs for me! I am trying not to overthink or over do this next move. A fresh TBI stroked 350 may be where I end up. My PCM will hook right up to it and everything else will bolt up too. I may need to upgrade ujoints in driveshafts, I've survived with 1310's for ever! (knock on wood)The bellhousing pattern is the same on the 4.3, 350, 6.2 diesel, 6.5 diesel, all LS based motors, the 8.1s, and even the Duramax engines.
You could also do a carbureted LS motor, but fuel injection is realllly nice.
With a small bit of soldering you can burn your own chips for around $100, I'd go that way before paying someone else for a generic tune. You can tune and retune til its just right. And thirdgen and binderplanet are great resources. Thats how I have a maf equipped tbi system on my f150 crawlers 351m. I just tuned the tpi system on my dads 67 c10 rat rod too. There are a few of us on this board with tuning experience that could help with advice.When it comes to changing a lot of things with a TBI engine, they can be a bear to program. One company makes a plug and play ECM that you can tune with your laptop. The only real way to get one running good if you stroke it, go with a decent cam or some better flowing heads is to data log and find someone to burn a chip for you. You can find a lot of information on thirdgen.com. Heard a membership comes with a free mullet, lol.
Sent from my iPhone using Tapatalk Pro
Sent from my HTC6545LVW using Tapatalk
Moates is what i use. All you really need is a zip socket, the flash burn 2, a cable either bought or homemade and some chips and youre youre tuning. The main fuel and spark maps are easy to tune, thats what the driving and datalogging does. The hard part for me is the cold start tuning because you only get one or two shots a day, lol.Good to know, I know they have the moates stuff so you can tune it yourself. I wanted to build a 383 but decided leave it pretty stock besides TBI intake, vortec roller cam, headers, and a 14 psi FPR spring.
