buggybuilder
- Mar 26, 2005
- under a rock
Damn i thought it was all about the bling!Tacoma747 said:"WHy does it take so darn long to build stuff?"
Cause you are makin it look too nice!
You can see the adjusters in this shaot on either side of the carrier caps.You can also see how much I shaved off of the ring gear.Ridgerunner said:I have a question how does shaving the bottom of the 14 bolt effect the preload on the carrier bearing? The case needs to be spread when installing and seting up the gears but there is now a weak spot.
buggybuilder said:Anyways from what ive seen/ learned/ read the most important thing seems to be keeping the arms in line with the ram at full extension where the ram shaft would be in most danger of being bent due to leverage.So what I did was made the arms to be straight with the ram at full extension and the reason the heims are on bottom is because I dont have the clearance to put the whole thing(ram,arms) up any higher without raising the ride height............hope it makes sense
buggybuilder said:Well its right about 5.25 from centerline to bottom of the new plate.I didnt measure before but Im sure its a bit better.Whats this same measurement on a 60?
