OldSchoolWhitey
- Apr 7, 2011
- Wallburg
So I bought a brand new badlands 120000 pound winch and installed it exactly as described in the manual. It has 3 50 amp circuit breakers that attach directly to the battery. My battery that I have is an AC Delco with only 580 cold cranking amps. My alternator is the biggest available without modifying to the top mount... which I do not want to do. Tha alt is said to put out 100 amps. All ofthis on a 1990 xj. My problem is no matter if my winch is under a load or not the circuit breaker continuously trips. Even with the jeep idled up slightly. What's the problem? Too small of a battery... should I run dual batteries ... or is there a problem with my circuit breakers? ?? Thanks for ANY suggestions!
