Nissan11
- Nov 29, 2005
- Marston, NC
So Im wanting to learn all I can about using a winch properly. I did a search and found this very helpful link (http://www.pirate4x4.com/tech/billavista/Recovery/index.html) but there are still a couple questions I have that were not answered.
1) I know it is not safe to hook the winch cable back to itself, but why?
2) I bought a 8,000 lb winch for my nissan frontier knowing that it may not be strong enough in extreme situations, but I was counting on being able to, for example, run the winch cable through a snatch block attached to a tree saver and doubling it back to my truck to double the pull force. I was even thinking if I was trying to recover a large vehicle that I could double the cable back to my truck and then through another block, hook it back to the stuck vehicle for even more power, thus using 2 blocks. I understand that using a block and doubling the cable back not only doubles the force, but doubles the stress on the winch and mounting points.
Now after reading the article in the link above I am extremely concerned with breaking the cable while winching. Correct me if I am wrong, but most winch manufacturers use a cable with their winch that has a higher breaking strength than the power of the winch, meaning the winch should stall before the cable breaks. Just for an example, if the breaking load of the cable on my 8,000lb winch is 8,500lbs then I should not even THINK about using a snatch block because the cable will, without a doubt break if the force of the pull is 16,000lbs.
So my main question is, should I just forget about ever using a snatch block with a wire rope?
Also, would putting a towel over the cable when winching
have any benifit at all if the cable snaps?
Thanks for reading my long post! I just really want to understand the safety guidlines before using something that could kill if improperly used.
