Winch sizing...
ut_prosim
Member
Hillsborough, NC
The time's come for a winch on the JKUR, and I've made up my mind to go with a Warn. My only question is, for the kind of terrain we have in NC and VA, where in that "1.5x - 2x vehicle weight" range should I be looking in as far as winch capacity? I have an ARB stubby bumper, so I could just about shoehorn a 9.5xp in there, but a 9.5cti would require more cutting than I'm comfortable with.
If I went with an XD9000 or 9000i, would that be stepping down too far? Thanks!
Any of the 9,000lb + winches should be plenty. If you are concerned if it's enough, grab an extra snatch block for that added capacity when needed.
Already picked one up!
I do need to do some more measuring. Per ARB, the maximum motor length I could fit in there is 6.7", but if I've learned anything about ARB's instructions, they tend to lean on the side of caution and unnecessary suggestions...
Just go with whatever looks cool. That's all that matters to most JK guys around here.
I have no angry eyes, LED headlights, or even plans to change my factory wheels. I'm not sure I'm in the right crowd sometimes :p
I agree. It's Rare that you will ever drag the full dead weight, not rolling, or sucked up to the axles in mud. Then a snatch block generally is sufficient.
I've seen more JKs with harbor freight winches than any other jeep platform. Just sayin...
At my last half marathon in VA, I saw a double-cab Brute with a Smittybilt. Guess the truck killed the budget. :bounce:
My Dayton 6k wouldn't budge my Cherokee when it was mired to the frame (5k across the scales). I didn't have a snatch block but it probably would have recovered it with one. Winch & grand Cherokee tugging got it out. It was buried, axles high centered, wheels spinning, muck to the bumpers.. lesson: don't ask your buddy on the way out if you went thru that mud hole or not.
I Don't have a winch but IME with guys that do .....
Get a winch big enuff to winch the guys you wheel with, I've always been told most winch guys use them more for buddies than themselves.
Matt
Matt
I'm mostly looking at a winch because I go alone and have no friends :p
But definitely, it'd be nice to be able to recover something bigger if I come across it...although a stuck dually F-350 may have to wait...
We use ours mostly for dragging trees. :lol: I uprooted a 24" sweet gum stump and pulled down a 18" sweet gum with one of the 8274s a couple of weeks ago.
But they get used for self-recovery, too.
Disagree. I snapped a steel cable on an 8,000lb winch with my 3,100 samurai.
I've always heard double your rig weight.
I have owned warn and snotty built and the last enchanted I bought was a harbor freight special. Truthfully unless your using it everyday the harbor freight is perfect. I was the go to guy for recovery when I lived in Alabama. About three or four times a week I'd get a call to come drag someone out of the creek. 80% of the time it was a dead pull as the truck had taken on water. My harbor freight winch 9k would pull anything I tried. And on the rare occasion it needed more a snatch block fixed it. Only time I couldn't get some one out lane was a f350 that was buried to the doors. Called a buddy. Two winches two snatch blocks and some anchor trees and he came out. Turns out the truck was on 42" tires. Learned to ask more about the truck be fore I hooked up after that one
Everyone talks crap about Smittybilt, I've beat mine up and drug myself and another jeep a trail for a couple miles, pulled a 250 out of the mud pit at the flats. Anytime I ask it to pull something up or out it has done it.
They're probably fine, but I used to work in manufacturing; in good conscience I can't spend that much on something Chinese-made when we have manufacturers here churning out excellent ones.
The Ms are, correct?
I knew about the VRs - at least some of the VR line.
keep an eye out for a sale and use a 20% coupon to pick up a 12k HF winch.
I'd feel dirty...
Check out the new VR Warns, they are cheap, new vr 8000 integrated with rope is less than $700, more amp draw than a zeon 8s. It's not a ctis or a 8274 but it looks like it will get the job done.
Going rate seems to be about $300-320 for 100' of 3/8" SK75.
Winchline.com, JM Rigging Supply, heck even Quadratec stocks Viking and Warn Spydura.
