guffey24
- Jun 7, 2006
- Hendersonville, NC
I have a older model Ramsey 9000lb winch, it had a bad motor, I put a brand new motor on it, it worked for several days, until I put a load on it, now the motor spins but it won't pull cable in or out, I pull it apart, key way is still in motor, everything seems to be in same place it was before the motor was replaced, no broken gears inside that I can see from the inspection plate, little plastic gear on outside seems to be working but not sure what it moves on inside
Any ideas?
Any ideas?
