Not trying to be an ass and just pointing to a link, but I remember this being brought up this past summer.
in ground dog fence
No problem....thanks for the link. I must have been busy the week of that thread......
Good tipOur dogs would "play" and they would unlatch and fall off... *NOT* worth the $35-50 each. I bought HD nylon "belt-buckle" style collars for <$10/ea, melted holes for the receiver tips (a .380 case & propane torch), and that issue was resolved.
We've had Dog Watch in 2 locations with great results. Typically not a flat install price (like PetSafe, Invisible Fence), but priced based on the the amount of wire actually used.
Currently, they have about a 3 acre run (based on the installers estimate of wire used around the perimeter via subsoil trencher).
1 dog (RIP) wouldn't get near it from just the beeping... the other required "a higher level adjusted on the collar" and stays put now.
They WILL require training... basically flagging (visual)/audio (beeping) walking the perimeter to get oriented. After that, it's adjusting the level to their level of stubbornness.
ZERO crap to mow/weedeat around, keeps them ON our property (there's 1000's of acres of nothing surrounding us, so could run for days) and still plenty of room to run away from predators (yotes & bear)... though they will sit at the perimeter and bark at the deer, who understand where the dogs will stop.
Another tip... the collars the receivers are attached to are the crappy plastic buckle type. Our dogs would "play" and they would unlatch and fall off... *NOT* worth the $35-50 each. I bought HD nylon "belt-buckle" style collars for <$10/ea, melted holes for the receiver tips (a .380 case & propane torch), and that issue was resolved.
Yes, I started using wireless fence only recently and I wish I had done it earlier! I got petsafe and it is a savior! If you are considering buying a wireless fence (which I think you should!) then here is a guide that will help you to see the differences between some of the options Best Wireless Invisible Dog Fence System (Jan. 2019)
So you work for petsafe? Joined a 4wheeling forum on the other side of the country to comment about a dog fence.
you ran them off before I could tell them I picked up a pet safe wireless from @TARider!! It seems to be working well. I did hear her run through it yesterday to go play with the neighbors dog so I turned up the correction level. They recommend 14 day training with 3 15 minutes sessions a day.....i think I got 3 in total. She knows where it's at and that it bites.....
