wiring guru's
userbmx1315
builds more then wheels
Bessemer City, NC
been working on swapping my 4.6 stroker into the 97 wrangler i got off the forum.
ive got it to turn over, but i dont have power to the fuel pump.
the wrangler was a 97 4cyl 5 speed,
i'm swapping in a 4.6 stroker and aw4.
the wiring harness and pcm i got off pirate. but cant remember if they were for auto or manual.
problems.
the jeep side wiring harness has a big gray plug (12wires) on the pass side fire wall.
on the motor side wiring harness theres a flatish black plug (11wires)
i dont know what these are really.
heres a pic of the plugs
the only thing that comes to mind is the NSS and TCU connectors for the AW4, but IIRC, they are only 8 cavity/5-wire connectors. One is gray, one is black, both end up where your pic is, rear/pass. side of the engine.
i figured out that both plugs are 12 wires. the black plug as a green with white wire in it. if i run a wire straight from the battery to it, the fuel pump kicks on. one of the other wires kicks the relay on.
these wires need to be plugged together, but some of the wires are diff colors. and i'm not a genius to figure out which is which.
the grey wire is part of the "power distribution" wiring harness.
the black plug is for the motor wiring harness.
after weeks of searching, i finally got it going. excitied now. wiring is not my stong side.
if anyone needs some info on doing there, pm me. i'm going to add it to my comp soon.
