VortecJeep
Powered by Uranium-235
- Aug 24, 2005
- Concord, NC
2002 Grand Cherokee Laredo. Mine does NOT have dual climate control.
Symptoms:
With A/C on and temperature setting at the lowest setting, sometimes the passenger side vents blow warm or even hot air while the driver side blows cool or cold air.
What I've done so far:
Removed the glove box so I could observe Blend door actuator. It works properly. I removed the actuator and could turn the shaft on the blend door by hand and hear at least 1 blend door moving.
What I think is wrong:
I think that maybe the passenger side blend door is broken or at least not moving like it should, thus warm air on the passenger side and cool air on driver side. When the door is down, that is the 'heat' position. Up is 'cool' position.
Question:
Is there a way to fix this without removing the entire dash like the tech manual says? If not, does anyone have a shop they'd recommend to tackle this? If the dash has to come out, I want to make sure it doesn't rattle after it goes back in.
Symptoms:
Question:
