WJ control arm
The joint is actually part of a plate that bolts to the housing. It is not in the control arm.
Loosen the nut a few turns and smack the "arm" with a hammer to break the joint loose (just like you would a tie rod end). The 3 bolts that hold the joint into the housing are tight as piss. Not a bad job, just a little frustrating.
thx i just took the whole thing out in one piece,didnt bother with ball joint separation
