MarsFab
Will work for money
- Oct 24, 2007
- Harrisburg, NC
Has it ever been wrecked?
Negative camber should not cause the steering to pull in one direction. If you have a pull and the caster is in spec you have something else going on possibly. have any of these shops inspected bj's or wheel bearings.
I don't know Wk front ends at all but for the most part dual a-arm setups work on the same geometry. Caster is what returns the steering wheel to center when you come out of a turn. No caster will wander all over the road. Too much caster will make the car dart once you pass a certain degree of turn. Some shops will actually put more caster in one side than the other to compensate for the crown in roads. Creating a slight pull on purpose.
If these guys truly have the caster in spec but can't get the camber right you shouldn't have a pull. Check your bearings, tire pressure, and ball joints.
If they're all good have the shop make the drivers side match the passenger side and see if the pull goes away.
