Wobbling front end on '95 YJ
Papaman
Raleigh
I've replaced the front shocks, the steering stabilizers, had the front end lined up... still when I slow below 30-35 mph on uneven pavement the tires wobble (sometimes) rather violently... whats next? Tie rods? King Pins?
HELP!!!
Mine did this really bad. Turned out that I had a tire that was bad. Moved it to the back and all was good again. With no stabilizer in place. I would check the tie rod ends and see if there is any play in them. When all else fails, hydro assist and your problems will be solved.
Toss the track bar and check the ball joints. Steering stabilizers are just a band-aid for bigger problems, I don't even run one!
i run 35's with no steering stabilizers, no problems, check tire balance. mine shook like hell one time when i lost a weight
wobble
I had to put longer lower control arms on my XJ after I lifted it to get rid of the wobble. If nothing else works that would be the next thing to do
its a YJ so it has leaf springs, with it being a '95 id check the ball joints and the unit bearings any slop or play will cause DW. Also while your looking at things, check everything im sure many parts could use some TLC.. -my
track bar
Toss the track bar for sure, even if that isn't the problem. Get under there and have somebody move the wheel back and forth, look for play in anything.
leaf spring bushings can contribute as well.
