REAL GOOD STIRFRY. I use the sideburner, on my propane grill outside. Gas indoor stoves w good ventilation work better than electric burners. You need a long handled, metal, rounded shaped spatula, and large metal, mesh type stainer to fit the roundbottom wok. BASIC WOKIN, Cut meat and vegeez into smallish, bitesize pieces first and hold seperate. Heat wok to about smoking, pour 1 or 2+/- tbls. PEANUT oil down the side of the wok and swirl it around quickly to coat the bottom of the hot pan. Add portions of the meat in batches so's not to cool the pan, and stir almost constantly. 2-3 mins. +/- and remove meat w strainer- repeat w all meat. Add more oil and swirl, then sliced garlic, sliced green onion ,yuns, w tops, whole dried hot peppers, or other flavoring ingredients and stir them a few mins. Remove w strainer and ad veg. in batches to not crowd the pan too much, and stir-fry 2-4 mins each batch and remove/repeat. Then put all the meat, veg, back in the pan and sauce of choice, Soysauce, terriaki, endless possibilities w the sauce, and stir and cook 2-3 min. and remove from heat. Top rice w big spoonfulls of the stuff and eat ! I have found the trick is to stabilize the pan somehow so you can stir and add/remove ingrediants w the other hand, and not tip the wok over. You can leave the garlic, onions out when you mix it, but chop and return the peppers if you want some spicy stirfry. This method works well w beefsteak, chicken, shrimp, deer meat, scallopes etc. and onions,broccolli,bell peppers,mushrooms, Heck about anything tastes great cooked right in a wok, ( HOT and FAST ). P.S. you may have to add more oil between batches if the pan gets dry when cooking alot of food. ENJOY
One more tip, to help drain the hot oil and keep it in the pan, tilt the wok one way while scooping the food up the otherside of the wok w the strainer, and hold there a few seconds before removing it.
