kaiser715
Doing hard time
- Jun 1, 2006
- 7, Pocket, NC
Got it mostly wrapped up today. Squared it to the fence and attached the slider rails on the bottom. Cut the slot, then did a 5-cut test for squaring the fence. Took a piece of 3/4" plywood 12" square, made a trimming cut on each side, rotating the board 1/4 turn each time. The fifth cut, I measured the thin cut-off with the calipers. .106 at one end, .208 at the other. Divide the difference by 4, and come up to needing a 0.025 shim on the right side of the fence. Got that in, and did another 5-pass cut, and the test piece came out .002 difference end-to-end. I am happy enough with that for wood work.
Sled stuck at first, used johnson wax on the bottom and runners and it does fine now.
