jammerdad
Member
- May 5, 2011
- burke county
Audi A4 timing belt and water pump. Got a pic if can get it to load. Had to take entire front end off along with radiator and intercooler
Wasn't the Z34 Lumina the one that you had to pull a cylinder head to replace the 30cent "O"-ring on the oil pump drive stub ( what USED TO BE the Distributor ) ? one hell of an oil leak if you left it alone.
I'm certain the reason the manufactures over engineer things and make it complicated is to force folks into taking it into the dealership where they get charged out the ars for repairs. I went by the Jaguar dealership today to get a quote on a maintenance check on a 2000 jag and for them to inspect everything (not fix) and rotate a few tires the bill came out to $1900! I'm like... dafuq?
I have done that job in 30 min start to finish. The secret is to start the car, pit in drive while holding brake and lunge the motor forward while mechanic #2 inserts an engineered 2x4 between motor and firewall.Since this has turned in to a general whine and moan wrench thread .....
90's Pontiac Grand Am alternator .... deceptively on the top "easy" to reach ... 3 bolts ... 1.5 hours to get the bottom bolt out.
90's Chevrolet Eurosport Lumina. We had a 4 door ( loved that car ... still miss it ) had to remove top engine mounts and push the car forward in gear so the engine would rotate on the lower engine mount away from the firewall ... just to change the rear spark plugs.
Matt
Any of the S series 94+ with a 4.3....spark plugs suck to change. The plugs also suck in the Camaros and such.
