criket
Blue Ridge 4x4
- Aug 18, 2010
- Dobson, NC
Do you plan to match the tires and wheels to the ones on your Wrangler? That would be cool too.
I am on the hunt for matching wheels and tires , though I wont put beadlocks on it just classic IIs . Once its painted to match and the same height I think its going to look good .Do you plan to match the tires and wheels to the ones on your Wrangler? That would be cool too.
i doubt you would have a problem as far as just pulling goes, i would just rather have a shorter trailer for like changing lanes and stuff like thatYour welcome , now go find you a few tubs to cut up .
Thats not a bad idea , it would be pretty easy to make the tongue shorter . I havent had it up to speed yet , so I dont know what it will tow like on the highway.
Fold down in the rear and most likely fixed in the front . The front will have four bolts holding it in place .Are you putting a fold down gate front & rear?
I plan on putting a storage box and jerry can on the front so thats why I plan on it being bolted in . I also hope to gain a little strength with it bolted , so that it will stiffen up the tub some .I think a swing out gate in front with food down in rear would be nice, but depends what your putting in it.
I dont know if I will run a spare on the trailer as my goal is to have the same size rim and tires as my Jeep on it . Then I will just need the one spare . If I end up with a different size I may try to mount it below . But the swing away is something to think about .also integrating the swing out spare tire carrier from the Jeep to the front of the trailer would be nice on the trails.
I like the caster idea , I was going to make a M 416 style kickstand but maybe I will add a caster to that .I have thought of building a trailer like this but would really like a nice caster to put under the tongue of the trailer encase i needed to disconnect & winch it up the trail separate. Maybe also a multi mount ATV winch that could store in the trailer but be used to winch the trailer on the trail.
Sent via telegraph
After working on it this weekend I am leaning towards having a steel panel broke and bolting or welding it in . This will stiffen up the tub significantly , but limit access to the front. I dont see the front access being an issue as I will have a rack mounted on the front anyways .I think that would depend on what you are planning to mount in the trailer.
I was thinking something like a rack on top of the fender wells. Then a front gate would allow you to reach in underneath to the items inside, like a trunk.
Sent via telegraph
Looking good, I'd take and cram the end of the conduit with rtv to preven stuff from getting in it.
Hey man, great build.
Where did you get the axle / springs from??
thanks!
thanks for the info!!
Looks good, you just filling in the front with that panel or is it going to be removable?
Sent from my iPhone using Tapatalk 2
Looks good bud
