Speed Freak
Member
- Jun 28, 2005
- High Point
My buddy has an 89 YJ with a 258/AX-15/NP231. When you drive under power everything is fine. When you let off there is a grinding noise coming form the transmission or the t case. It's like a gear not meshing noise, not like a missing 2nd gear noise. If you push in the clutch the noise goes away. He installed a new clutch thinking the release bearing was the problem but it didn't help. We removed the rear drive shaft, drove it in front wheel rive and it's still there. We pulled the rear of the tcase and the front drive chain seemed to be loose but I dont know how to check if it's in tolerance. Would a loose chain even cause this noise in 2wd? What else should we check b4 pulling the trans?
Thanks for you help,
Guy
Guy
