hunterdan
- Apr 13, 2009
- Morganton,NC
Selling my 2014 Camaro.
LS
3.6L
6-sp manual
82K miles
The good;
It runs and drives great. Newer tires and clutch. Clean interior 323HP
Not so good;
(Paint....)
It had a fender bender on passenger rear quarter and was fixed. It's not noticable until you really look. The rear fin has a little paint peeling. It was an add on and should be removed,sanded and repainted. The drivers side has a couple paint blems and needs correction.
(AC ...)
was working fine until I installed a new battery. After the battery it would stop working and the start working intermittently. It eventually stopped blowing cold. I took it for a quick look at local shop. He said freon is full and clutch is not stuck. Said he would need more time to check for relays wiring etc.
(Passenger seat warning)
Dash gets a message at start up of air bag occupant etc. Basically the occupant sensor has a loose wire which is common or may need new seat sensor.
Nice car that's never seen a dirt Rd. Very clean underneath and 0 rust.
Just installed frt and rear end links, brake pads and alignment.
That's about it.
$10K
LS
3.6L
6-sp manual
82K miles
The good;
Not so good;
(Paint....)
(AC ...)
That's about it.
$10K
