Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Ok I know some of ya'll on here are runnin the xj 8" lift coils or close to it, wonderin if you could do me a favor, one is measure the length of your coil on the vehicle sitting at normal ride height from top to bottom, then also if you could measure the diameter of the springs that be sweet.
Same thing If you have an early bronco with a non progressive lift spring on it let me know what lift it is, and the same thing as above length sitting under the vehicle at normal ride hieght and overall diameter.
Preciate it, I'm tryin to figure out what size spring I'm gonna need on my s10 blazer to level it out with the rear lift amount.
