- Apr 18, 2005
- Greensboro, NC
Bleeder has to be above the hose. And it is easy to get them on the wrong sides, seen it done before. Hope that is your case, easily fixable
**Snip**
So, last night we took apart the proportioning valve. Cleaned the crap out of it and put it back together without the o-ring and bled it. Doing this is supposed to allow more pressure to go to the rear brakes. Well that had no effect whatsoever. We noticed a hissing sound coming from around the power booster where it mates to the master cylinder. Took off the master cylinder, removed the rubber seal on the booster, cleaned it, cleaned around the booster, and even ran some black RTV around the master cylinder. Buttoned everything back up and no more hissing sounds, but still no brakes.
**Snip**
Did you do this part to the prop valve ?
http://www.4x4wire.com/jeep/tech/brakes/xj_wjbrakes03/valve/index.htm
