Macdaddy4738
- Jun 1, 2005
What is the preferred bushing type? I don't really take this thing out often, but I do live like ten minutes from URE, so there is always the possibility.
Browsing through some other forums, I think I'll stick with rubber.
Is there any reason to upgrade my control arms from the stock ones? I can spend 80 bucks and get both front LCA's stock, or spend 280 and get heavy duty upgrades. Like I said, I don't take it out too often, because its my DD, but it does see trail time every once in a while.
Are you running a stock lift? If so there is no benefit to change them for mild use. You can always get super cheap used control arms as spares. The bushings are designed to last the life of the vehicle.
