Carolina YJ Well-Known Member Joined Mar 30, 2005 Location charlotte Feb 18, 2009 #1 Anybody have any advice on what type, psi, etc fuel pump to run w/ a stock 4.0 w/ a fuel cell??
RenegadeT no shirt,no shoes,no dice Moderator Joined Mar 24, 2005 Location Stokesdale-Greensboro Feb 18, 2009 #2 E2000
Tom@Hilltop_Machine Well-Known Member Joined Mar 31, 2005 Location Rural Retreat, VA Feb 18, 2009 #3 Contact Hesco. They will get you straight.
Been jammin Member Joined Jan 5, 2009 Location granite falls Feb 18, 2009 #4 Ford heavies run external(I believe it is the e2000) with the 460s running 95 psi, and you have a factory regulator that reduces it to 35/40 psi. I ran one in the xj I had, works well. There only $85 to $90 at all your local part stores.
CTRaceWorx Well-Known Member Joined Aug 23, 2007 Location Charlotte Feb 18, 2009 #5 E2000, If you don't a return you'll need a adjustable regulator. I've ran them with good luck so far.
Carolina YJ Well-Known Member Joined Mar 30, 2005 Location charlotte Feb 19, 2009 #6 thanks for the help, ill look into it
