98xjjeep
Member
- Dec 11, 2008
- Greensboro, NC
So I decided to upgrade my crappy rustys short arm kit that i purchased a few years ago. I wanted something that won't bind, gives me good down travel, a better more solid ride and something that isn't the typical radius arm all the cherokee guys run.
I bought 7/8" hiems for the single upper from Ruffstuff and will be using 1.5" .120 wall DOM. The upper will be sleeved at the ends with 1.75" .120 tubing to help with strenth.
For the lowers I have bought ballastic 2.63" flex joints for the axle end. I am using stock rubber bushings for the frameside to keep the ride good and they flex more then poly. I will be making the lowers out of 1/4" plate and the design is kind of confusing so you just have to wait till I build them and take pics.
All the brackets are 1/4" and can run either 7.5, 8.5, or 9.5 inches of seperation. The new lower brackets will give me about an inch of extra clearance under the axle.
So far I have taken the axle off along with the control arms, steering, shocks, ect. I have the axle on the table ready to cut the old stuff off and weld the new stuff on. I still have to work on bracket for the frame side. Hopefull i will be done by Wednsday but we will see.
I will post pictures in a second....
